How to Rip Blu-ray 3D to AVI 3D Video with DVDFab Blu-ray Ripper?
08/11/2022
Do you want to know whether you can watch 3D AVI videos on your 3D TV or not? Check your 3D TV manual, if the spec says that it supports AVI format, then you should be able to watch 3D AVI videos on it. If this is the case, then you need a 3D AVI ripper software to convert 3D Blu-rays into 3D AVI videos, to save the original disc from being accidentally damaged. DVDFab Blu-ray Ripper is just the right 3D AVI ripper software you are looking for.
Just check this guide out:
Convert 3D Blu-ray to 3D AVI Video > Step 1: Download and install the latest DVDFab 9 onto your computer;
Convert 3D Blu-ray to 3D AVI Video > Step 2: Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the target 3D Blu-ray;
Convert 3D Blu-ray to 3D AVI Video > Step 3: Click the Profile Box (or Profile Icon) which takes you to DVDFab Built-in Profile Library, and then select one profile from the “3D Format” column and “AVI” section, for example, “3d.avi.xvid.mp3”;
Convert 3D Blu-ray to 3D AVI Video > Step 4: Click “Advanced Settings” button behind the Profile Box to do corresponding settings regarding to video, audio, subtitle and 3D formats;
Convert 3D Blu-ray to 3D AVI Video > Step 5: Click the “Edit” button at the top right corner of Operation Window if you want to customize the resulting 3D video. After you have done here, return to the main interface to “Start” the converting process.
Note: the previous Blu-ray 3D Ripper has been integrated into Blu-ray Ripper. In other words, the redesigned Blu-ray Ripper now is capable to rip 3D Blu-rays into various 3D videos.
Product you need order: Blu-ray Ripper
For more information, please go to: https://www.dvdfab.cn/blu-ray-ripper.htm
